horrendous vibrating pump !
19 Feb 2008
Home
ive got this pump...
in here...
the vibration is so loud is resonates through my desk.
i have the foam pad on the bottom of the pump and a bit of foam as well.
would this bracket help to stop the vibration's ?
also if anyone has any idea's on where to put the pump would also be helpfull.
apart from that it all sound's pretty quiet.
went from this set up...
no air at all,had the pump running for 4 days before i put the rest of the pc in.
is suspending the only option.
this is so loud and driving me nuts.
