Hi Guys,
this is my first water-cool build and I have an odd problem.
I purchased the following
Monsoon 16/10mm (ID 3/8 OD 5/8) Free Center Compression Fitting Six Pack - Orange
XSPC HighFlex Hose 3/8" ID, 5/8" OD, 16/10mm, 2m, Red/UV Orange
The problem I have is that the hose is loose on the barb.
I ran the leak test for 24 hours no problem but then fitted the board in and seated the CPU then notice that the hose was working it's way down the barb on pretty much all the fittings.
I no don't want to fire the PC up as I have no confidence that the hoses will stay in place and when they heat up more I'm sure they will just come loose and leak.
Now I must be missing something as the fittings and the hose are the same size which I assumed was the way to go so what am I missing?
Should i try the 7/16 - 5/8 hose or change the compression fittings?
not sure which direction to take now.
