- 23 Nov 2009
- North Leicestershire
Never used to have a problem when i had my 980ti but the 1080ti back plate is getting so hot it's causing my cpu to get up 75C before this with the 980ti i would only ever see 65 max.
I've moved the card to the lowest slot possible on the mobo but the rising heat is travelling into the noctua NH-D-14
Rather crude attempt at showing my case fan layout, Hoping someone can give me some better ideas as i don't really want to be watercooling again at the minute, as a side note the cpu fans are hitting 100%once the temp reaches 73 and the cpu throttles at 75, as a short tem solution i've dropped my overclock to 3.8
