Jokester said:My very first PC had the PCI cards glued in with a hot glue gun.
Jokester
thefishdude said:are yoru hardrives western digital ones ??? they are often loose but they do a secure conenct cable you can use has alarge plastic peice that cothers most of the back of *** hardrive to hold on securely. youjust have to use the 4pin molex as the power socket instead of sata power.
