Hot laptop
22 Dec 2012
Hi guys,
I just finished re applying thermal paste to my brother's HP G56-100SA laptop, because it's CPU idled at 60 deg C. I used Arctic MX-2, which is decent stuff, but the laptop now idles at 45 deg C, which is still quite high.
The original thermal paste was nearly non-existent, which explains the drop of 15 deg c. The laptop already has seriously bad cooling, so it may just be that.
I have checked and there are no programs that are CPU hogging, it stays around 2-3 percent load just at home screen due to the single core and single thread.
Any ideas?
Thanks,
Chris
45 is really not that high for a laptop. especially in summer.
mine has always idled at just under 50. and I open it up and clean it up every 6 months or so.
good laptop cpus are designed to work with the 50-95C range. you can't directly compare to desktops
