Hot NB Temps?
Permabanned
13 May 2011
So im overclocking my AMD phenom 1090t to around 3.8ghz. My core temps are fine but im a little concerned with my NB as im only running an old AM3 M-ATX board. Ive seen my NB gets as high as 60 under full loads, also voltages are a huge problem for me as ive heard older AM3 boards have problems with voltage my board doesnt have a setting to change the actual vcore so I have to use CPU OVERVOLTAGE and change the LLC to 19% to get a higher vcore but it still changes while in windows.
Are my NB temps too high? and do you think its time for a new board
I was thinking to get a new NB heatsink like the zalman one but looks like overclockers dont have it anymore, does anyone know how easy these are to fit and will it fit on my MB?
