** Hot New Additions to the OCUK Range - TP-Link **
  • Thread starter Thread starter rjk
  • Start date Start date
rjk
rjk
OcUK Staff
8 Aug 2007
Hi Guys
About to go live, we have an excellent new range of higher performance TP-Link products.
Price points for these products are a little higher than our current TP-Link range but after some testing of a large range of samples, TP-Link have really set these products aside as being higher end offerings.
Performance, interfaces and aesthetics have all been subjected to an overhaul here.
TP-Link Dual Band N600 Concurrent Wireless Gigabit Router (TL-WDR3600) @ £59.99 inc VAT
Highlights:
•Simultaneous 2.4GHz 300Mbps and 5GHz 300Mbps connections for 600Mbps of total available bandwidth
•2*USB Ports - Easily share printers, files or media with your friends or family locally or over the internet
•Full gigabit ports ensure ultimate transfer speeds
•Achieves blazing WAN to LAN throughput of over 800Mbps with hardware NAT
Only £59.99 inc VAT.
ORDER NOW
TP-Link Dual Band N600 Concurrent Wireless Router (TL-WDR3500) @ £52.99 inc VAT
Highlights:
• Simultaneous 2.4GHz 300Mbps and 5GHz 300Mbps connections for 600Mbps of total available bandwidth
• 1 USB Port - Easily share printers, files or media with your friends or family locally or over the internet
• Wireless on/off switch- Green wireless lets you simply turn the wireless radio on or off
Only £52.99 inc VAT.
ORDER NOW
TP-Link Dual Band N900 Concurrent Gigabit Router (TL-WDR4900) @ £109.99 inc VAT
Highlights:
• Simultaneous 2.4GHz 450Mbps and 5GHz 450Mbps connections for 900Mbps of total available bandwidth
• Full gigabit ports ensure ultimate transfer speeds
• Achieves blazing WAN to LAN throughput of over 900Mbps with hardware NAT
• CPU Clock Speeds of up to 800MHz can handle more data much faster
• 3*5dBi external antennas and 3 internal antennas provide maximum wireless coverage and reliability
• Dual USB Ports - easily share printers, files or media with your friends or family locally or over the internet
Only £109.99 inc VAT.
ORDER NOW
TP-Link N600 Wireless Dual Band PCI Express Adapter (TL-WDN3800) @ £30.95 inc VAT
Highlights:
• Dual Band support - 2.4GHz or 5GHz channels bring an optimized HD video streaming, file sharing and online experience
• Wireless speeds of up to 300Mbps
• Two antennas increase wireless performance and stability
Only £30.95 inc VAT.
ORDER NOW
TP-Link Universal Wall-Plug Range Extender (TL-WA850RE) @ £34.99 inc VAT
Highlights:
• Range Extender mode boosts wireless signal to previously unreachable or hard-to-wire areas flawlessly
• Miniature size and wall-mounted design make it easy to deploy and move flexibly
• Easily expand wireless coverage at a push of Range Extender button
• Ethernet port allows the Extender to function as a wireless adapter to connect wired devices
Only £34.99 inc VAT.
ORDER NOW
TP-Link 300Mbps Wireless N Gigabit ADSL2+ Modem Router (TD-W8970) @ £52.99 inc VAT
Highlights:
• All-in-One Device: ADSL2+ Modem, NAT Router, 4-Gigabit-Port Switch and Wireless N Access Point
• 300Mbps Wireless speed and Gigabit Ethernet ports, ideal for multiple HD video streams
• Versatile Connectivity: ADSL or Ethernet WAN for multiple Internet connection types
• 2 USB ports for storage sharing, printer sharing, FTP Server and Media Server
ORDER NOW
TP-Link N600 Dual Band Wireless ADSL2+ Modem Router (TD-W8980) @ £81.98 inc VAT
Highlights:
Only £81.98 inc VAT.
ORDER NOW
TP-Link AV500+ Gigabit Powerline Homeplug Adapter with AC Pass Through (TL-PA551) @ £48.95 inc VAT
THIS PRODUCT IS A UK PLUG AND NOT EU PLUG AS THE IMAGES SUGGEST
Highlights:
• Integrated power socket to allow additional devices access to power
• HomePlug AV standard compliant, high-speed data transfer rates of up to 500Mbps
• No new wires, Easy Plug and Play operation, No configuration required
• Patented Power-Saving Mode automatically reduces power consumption by up to 85%*
Only £48.95 inc VAT.
ORDER NOW
TP-Link AV500+ Gigabit Powerline Homeplug Adapter with AC Pass Through, Twin Kit (TL-PA551KIT) @ £79.99 inc VAT
Highlights:
• Twin Pack design helps establish a basic powerline network
Only £79.99 inc VAT.
ORDER NOW
TP-Link 300Mbps Wireless N ADSL2+ Modem Router + USB port (TD-W8968) @ £39.95 inc VAT
Highlights:
• All-in-One Device: ADSL Modem, NAT Router, Switch and Wireless N Access Point
• 2.4GHz, IEEE802.11b/g/n, up to 300Mbps data transfer rates
• USB Port for Storage Sharing, Printer Sharing, 3G Modem* Sharing, FTP Server and Media Server
• Supports the latest Internet Protocol IPv6 to future-proof your network
• Ethernet WAN (EWAN) offers another broadband connectivity option for connecting to Cable, VDSL or Fiber modems
• IP QoS features for improved bandwidth control across the network
Only £39.95 inc VAT.
ORDER NOW
The n600 doesn't seem to have a bad specification, would be a good replacement for the homehub3 or there's the Asus range.
Just placed an order for the N600 (TL-WDR3600) to replace the homehub, which while has been adequate I'd like a few more options, this seems to fit the bill and there's always the DD-WRT option :D
Arrived today, made a few changes to the Wifi (renamed the SIDs). Connected to BT Infinity and got my best ever benchmark.
Looking through the GUI I thought I'd check the firmware. One revision old so updated the firmware (available Here N600).
Then did another test and gained a few more Mbps.
Could be completely unrelated but my line has been solid 50Mbps before replacing the HH3.
Got some nice features for bandwidth control (doubt I'll bother with) and seeing individual bandwidth per IP.
Can;t fault it so far for £59.00 (N600). See how it fairs over time now...
Hi guys,
Anyone know if the TD-W8968 supports NO-IP accounts? Need a cheap decent ADSL router that supports this.
Aha, their firmware page says it's been added, superb
Am I missing a few things with those "gigabit" adapters? Firstly, for less than half the price I could have a pair of the same without the extra plug socket (I'd rather spend £2 on 2 3 way adaptors if I really had no other choice), and "gigabit"? 500m/bits is not gigabit.
Pass through adapters have always been expensive. In addition to the convenience of not loosing a socket, they also act as a mains filter helping to keep any electrical noise generated by the attached equipment from the mains.
They're Gigabit because they have Gigabit network ports. There are 500Mbps adapters that only have 100Mbps ports, so it matters.
I'm loving my N600. It's been rock solid for 42 days and counting. I've got iPad HD streams over wifi, a NAS and my computer with no glitching at all. Great bit of kit for the price.
Hi guys,
Seems like a great router so far, faultless in all tests
You have the router or router/modem? We just got Virgin 100Mb with a Superhub - it's crap. I can barely get a signal in my room which really isn't that far from the living room. Thinking of getting a router (Asus N56U or TP N600 as it's cheaper) and letting the Superhub be just a modem.
Why are there rarely/never reviews of TP-Link stuff?
Im using the N600 with my VM hub setup as modem only, wireless reception has been good and have also flashed the firmware with dd-wrt, its been great so far. Only thing I have n't really worked out yet is how to get the printer to work across the network using the USB sockets.
