** HOT NEW TP-LINK NETWORKING PRODUCTS **
rjk
rjk
OcUK Staff
8 Aug 2007
Hi Guys
We have some very exciting new products coming in soon from TP-Link.
Very fast wireless PCI cards as well as the upcoming wireless Powerline kit. The powerline kit is expected in the next few months but the rest of the hardware should be here in the next few days.
For anyone looking for networking solutions, our existing range of TP-Link is hard to beat, we have all of their hottest products listed from basic starter networking gear right up to enterprise solutions.
TP-Link 450Mbps Wireless N Dual Band PCI Express Adapter (TL-WDN4800) @ £38.99 inc VAT
What This Product Does
TP-LINK’s 450Mbps Wireless N Dual Band PCI Express Adapter, TL-WDN4800 allows you to connect a desktop computer to a wireless network and access a high-speed wireless network connection. Complying with IEEE 802.11a/b/g/n, the device can use the 2.4GHz or 5GHz channels and provide wireless speeds of up to 450Mbps which is ideal for users seeking a highly robust, bandwidth intensive wireless networking experience, particularly with HD video streaming and online gaming.
Dual Band
Dual Band is the latest wireless technology allowing the adapter to connect with a 2.4GHz or 5GHz network. This allows you to check e-mail and browse the Internet using the 2.4GHz band or stream HD movies and other media on the 5GHz band. The advantage of working on the 5GHz band is that, unlike the crowded 2.4GHz band shared with microwaves, cordless phones and other wireless networks, it has much less interference and can provide a more stable wireless signal, which is ideal for online gaming and HD video streaming.
Wireless N Speed up to 450Mbps
Both the adapter’s 2.4GHz and 5GHz bands support the maximum speed of up to 450Mbps, which generates a maximum theoretical wireless throughput bringing you a limitless wireless experience.
WPA / WPA2 Encryptions - Advanced Security
WPA/WPA2 encryption standards ensure your wireless connection is safe from intruders.
Easy Operation
TL-WDN4800 comes with a CD utility that helps you complete the software installation and wireless network settings, including security configurations and wireless connection, which makes setting up your network so easy that even for novice users should be up and running in minutes.
Only £38.99 inc VAT.
ORDER NOW
TP-Link 300Mbps Wireless N PCI Express Adapter (TL-WN881ND) @ £16.99 inc VAT
Wireless N PCI Express 2.0(x1) Adapter TL-WN881ND allows you to connect a desktop computer to a wireless network and access high-speed Internet connection. Comply with IEEE 802.11n, they provide wireless speed up to 300Mbps, which is beneficial for the online gaming or even HD video streaming.
Wireless N - Speed & Range
MIMO (multiple input, multiple output antennas) technology, it shows more excellent abilities of mitigating data loss over long distances and through obstacles in a small office or a large apartment, even in a steel-and-concrete building. Above all, you could easily pick up the wireless network during long-distance connection where legacy 11g products may not!
CCA Technology - Stable Wireless Signals
Clear Channel Assessment (CCA) automatically avoids channel conflicts using its clear channel selection feature and fully realizes the advantages of channel binding, greatly enhanced the wireless performance.
As for the security of WI-FI connection, WEP encryption has been no longer the strongest and safest guards for outside intrusions. TL-WN881ND provides WPA/WPA2 encryptions that are created by the WI-FI Alliance industry group, promoting interpretabilities and security for WLAN, which could effectively and efficiently protect the wireless network.
Bundled CD for Easy Operation
TL-WN881ND comes with a CD with utility that helps you complete the software installation and wireless network settings, including security configurations and wireless connection, which is convenient for users, even for novice users.
Only £16.99 inc VAT.
ORDER NOW
TP-Link 300Mbps AV200 Wireless N Powerline Extender Starter Kit (TL-WPA281KIT) @ £73.99 inc VAT
TP-LINK’s Wireless N Powerline Extender Starter Kit extends an Internet connection to every room of the house over existing electrical circuitry. All devices in the room have two options to get access to TL-WPA281, whether through wireless or using an Ethernet cable. With 200Mbps Powerline link rate and 300Mbps wireless N rate, it is ideal for bandwidth consuming or interruption sensitive applications like video streaming, online gaming and Internet calls. With TL-WPA281, Internet can be available everywhere in your house.
Up to 200Mbps, 300 Meters
With advanced HomePlug AV technology, TL-WPA281 Starter Kit provides users with stable, high-speed data transfer rates of up to 300Mbps on a line length of up to 300 meters. Together with its built-in Qos and powerful AES encryption, the TL-WPA281 is a great choice for a whole home solution to connect all network compatible devices--from computers and game consoles to set-top boxes for IPTV to printers and NAS hard drives.
300Mbps Wireless N Rate—Extend Wireless Coverage
With wireless speeds of up to 300Mbps, users can effortlessly extend their network via the existing powerline and broadcast a wireless signal to another area of their home or office.
Multiple HD Streaming
200Mbps powerline and 300Mbps wireless ideal for lag-sensitive applications.
Pair Button for Easy Network Security
Simply by pushing the Pair button on the adapters, users can set up a hassle-free Powerline network within minutes, complete with 128-bit AES encryption for network security and data protection. It's that simple!
1. Plug the adapter into the power outlet
2. Connect the device via the network cable to the adapter
3. Press the encryption buttons—and you're done!
WPS One Button Security
Compatible with Wi-Fi Protected Setup™ (WPS), TL-WPA281 Starter Kit features WPS One Button Security Setup that allows users to almost instantly setup their security simply by pressing the "WPS" button on the adapter automatically establishing a WPA2 secure connection, which is more secure compared with WEP encryptions. Not only is this faster than normal security setups but more convenient in that you don't need to remember a password!
Support QoS for Advanced Multiple-media Optimization
Quality of Service (QoS) function prioritizes the bandwidth requirements of data traffic. Users can choose which type of traffic they will use -- Internet, Online Game, and Audio or Video, Voice over IP, and the QoS functions will guarantee clear, instant reproduction of that application, even when other applications are running on the network at the same time.
Only £73.99 inc VAT.
ORDER NOW
TP-Link 300Mbps Wireless-N Range Extender (TL-WA830RE) @ £29.99 inc VAT
TP-LINK's TL-WA830RE 300Mbps Wireless N Range Extender is designed to extend the coverage and improve the signal strength of an existing wireless network to eliminate "dead zones".
Combined with leading wireless N technologies, superior security and wider compatibility, TL-WA830RE makes it a secure high speed solution that can help you keep an existing wireless network unchanged and vastly improve the network's coverage, giving you the freedom to enjoy Internet anywhere uninterruptedly in large areas such as homes, hotels or small offices without worrying about coverage limits.
Adopting IEEE 802.11n advanced MIMO (Multi Input Multi Output) technology, TL-WA830RE simultaneously works through two antennas to Tx and Rx to overcome the interference and signal degradation when traveling long distances or through physical barriers in a small office or a large apartment, resulting in an incredible improvement in the wireless performance, even in a steel-and-concrete building. Above all, you could easily pick up the wireless network during long-distance connection where legacy 11g products may not!
Incredible Wireless Extension
TL-WA830RE is designed to select "Range Extender" as the default wireless mode, working as a "relay station" to repeat the wireless signal flawlessly to longer distance where is previously outside the coverage of the existing wireless network. Due to leading Wireless N technologies, it can overcome obstacles and enhance overall network signal quality, then providing the same reliable network connecting as wired network. Better still, TL-WA830RE can also work in the conventional AP mode, accessing the Internet via ADSL/Cable modem and linking the wireless and wired network together.
One Button for Connection
TL-WA830RE features Range Extender Button that allows users to setup the wireless connection with both unsecured and secure network simply by pressing the "Range Extender" button for about 5 seconds. Especially when connecting to the unsecured network, the whole connection process seems to be a snap for any users in that all you need is just a push of a button and a few seconds' waiting without any extra operation at all!
Full Compatible with 802.11b/g/n Devices
TP-LINK Wireless N Range Extender TL-WA830RE is fully compatible with all IEEE 802.11b/g/n devices, including routers, gateways, access points and adapters. Specifically, it can not only maximize performance with 802.11n products, but also achieve full capacity when linking with 802.11b/g products. Therefore you can make full use of all your existing wireless devices without any replacement cost, and even upgrade your wireless network off to Wireless N age.
As for the security of Wi-Fi connection, WEP encryption has been no longer the strongest and safest guards for outside threats. TL-WA830RE provides WPA/WPA2 encryptions (Both Personal and Enterprises) that are created by the Wi-Fi Alliance industry group, preventing the wireless network from outside threats.
Only £29.99 inc VAT.
ORDER NOW
The TP link stuff is pretty good. Before using a wired connection for my internet I used a TP link 300mb/s USB card from OcUK and it didn't affect the ping on games at all, especially compared to the card I had previously which was a belkin variant. Vastly better quality.
