I have a P180 which is generally quite a good cooler, but for one spot in the case.
The case is designed that the lower hard drive bay and the power supply are in a 'channel'. The Fan located in the centre pulls the air over the hard drives, and then pushes it over the power supply. This works really well, to the point of the PSU fans hardly ever actually turning on (I hear them now and then when gaming).
In the mobo section, I have a Gigabyte DS3 board, with a C2D and BFG8800GTX. The GTX is a really long card, and effectively cuts the mobo section in two. The part above the GTX is cooled by using two 120mm exhaust fans located at the top of the case. This section is kept quite cool, and the CPU temps are pretty low too.
The problem is the section below the GTX. IE between the GTX and the bottom channel where the PSU resides. This section is consistently above 45 degrees C. It was worse, running at over 57 at times when gaming, but an additional 120mm fan in the front brought that down a bit. I have also just mounted a 60mm fan to the back of the case in a small section that looks like it was designed to hold 40mm fans (2 of them side by side maybe).
Problem is the GB Easytune software still reports the system temp at 48 degrees. I also have a cooldrive 4 unit in the case, and I have placed a sensor in this area as well, which is currently reporting 42 degrees. Physically placing my fingers near the board, I can feel a lot of heat in the area.
Does anyone have suggestions for cooling this section?
