Hot stuff !?
2 Apr 2011
My PC has been getting BSOD half way through games and been looking at temps GPU and CPU have been hitting 80C.
I did a stresstest but stoped it as the temps got massive and didnt want to push it.
Mobo/Gpu/Cpu seem all very high to me,
My PC idol:
http://img707.imageshack.us/i/idlexc.png/
Im not sure if this is normal or not, i have orderd thermal compound for my CPU and hope that solves it but still not sure. The motherboard and GPU seem to hit high temps also and having hard time trying to find MAX temps for my hardware.
tnx for any advise given.
80c for the cpu sounds a bit hot to me. thermal compound and a good dusting out is the best place to start.
80c for GPU is fine, download and run Prime and Core Temp or Real temp. These will show show your cpu temps at 100% ~ load on the cpu with Prime running.
What cooler and case are using.
i have cooler is intel E29477 002 and case Coolermaster Elite 335 Case - Black [RC-335]
PSU is ocz ocz600mxsp 600w ( i dont know if that is any use)
