Hope I've put this in the right subforum.
I'm unable to connect a drive to the hot swap bay in a new Xigmatek Midgard II case. I'm pretty sure I've done everything right but any pointers would be most helpful:
1. I have a 120Gb SSD on Sata3 port 0 mapped to drive C: - the OS is installed on this drive.
2. I have a secondary drive on Sata3 port 1 mapped to drive E:
3. The hot swap bay is connected to Sata2 port 2.
4. In the Gigabyte BIOS, the Sata mode is set to AHCI.
5. In the ATA port section of the BIOS, I have enabled 'hot pluggable' for port 2.
The HDD is a DiamondMax 21 250Gb which is supposed to be hot-swappable. But if I insert it into the bay, nothing happens and it's not detected by Intel's RST version 11.1.0.1006
Things I've tried:
a) checked that the bay is connected to a power supply
b) connected the Sata cable to a different port
c) installed the HotSwap! utility but that fails to detect the drive
d) booted with the drive installed in the bay, and it's still not recognised
e) set all ports to 'hot pluggable' in the BIOS
The drive works fine if I connect it directly to any of the free Sata ports so there's no problem with it, or the Gigabyte z77-D3H motherboard. Basically, I'm baffled as to why it won't work via the hot swap bay.
The only other thing which seems a tad strange to me is that the AHCI controller is shown as an Intel 7 series/C216 chipset which, according to the Intel site is compatible with Xeon processors, and this PC has a 3570k fitted. I've been told there's little difference but should I be using the Z77 chipset? From the Intel site there are slight differences between the chipsets, in particular the C216 makes no mention of USB3 or multiple monitor support.
Any help would be most appreciated.
Things I've tried:
