- 20 Feb 2009
- Ashton-Under-Lyne
Currently undergoing a bathroom renovation, and as part of this, I'm installing a vented HWC, that will be pumped for the shower (expecting ~20-25L/min combined flow out of the shower).
An unvented cyclinder was considered, but we've only got a 15mm incoming supply, so have limited flow available, so am going with a pumped vented, so the flow to the shower will be uninterrupted.
The thing I'm having trouble deciding on, is the size/type of vented cylinder. I currently have a gas boiler to heat it, but am likely to switch to a heatpump at somepoint in the future & don't want to have to replace the cylinder at the same time. This has pointed me towards getting a cylinder with a heatpump coil (from what I can find, this essentially means there's a much larger surface area in the coil, so the heat is transferred more effectively to the water in the tank than with a standard coil). However as this cylinder is for the shower only, does this matter? If it takes 4+ hours to fully reheat from a heatpump (rather than say 40mins), that doesn't really matter, as long as it's large enough to begin with to provide enough hot water for 2 showers in quick succession. This makes me think I should just aim for a ~300L tank, but with a standard coil, which would be significantly cheaper than a HP version. But is this a bad idea?
I've also seen cylinders that are twin & even triple coil and/or solar cylinder, which could be a middle ground.
In summary, I think I have the following options:
- Get a ~300L standard cylinder & live with slower heatup times if/when I get a heatpump
- Get a ~300L HP cylinder
- Get a smaller (~200L?) HP cylinder (I'm not sure this is worth it, as the price difference is fairly minimal from option 2)
- Get a ~300L twin/triple coil/solar cylinder (which I expect would operate somewhere in-between option 1 & 2 for heatup times)
. So I didn't bother.
