- 3 May 2004
- Kapitalist Republik of Surrey
Could be one for the plumbers here but anyone with experience with their heating and hot water might be able help me. The hot water pump is getting stuck on. We've got an old conventional system with hot water cylinder. The hot water is set to come on between 5:30 and 6:30, but the pump isn't switching off. It'll run all day if I just leave it but gets incredibly hot, presumably because it's pumping against a closed valve. So I guess I need to find out if this is a serviceable item or if you have to replace it, or if there's a controller that's at fault.
Some info that might help:
-I replaced the central heating timer from an old mechanical one to a digital one. Direct swap and appears to work fine. Everything worked ok for the first 6 months we lived here.
-There's a power switch in the airing cupboard that appears to supply power to the pump (not the immersion heater). If I switch off the pump here, sometimes it clicks the pump off and it'll stay off and go back to working correctly. Sometimes it'll stay off for one cycle and stick on again next time the hot water comes on. Sometimes the pump just comes back on again when the power comes on and stays on, like it's doing at the moment. I noticed the switch in the airing cupboard also switches off the central heating timer (which is downstairs with the boiler) and I don't know if that's correct or not.
-You'll probably want to know what type of system it is. It looks identical to the 'conventional system' diagram on this page: http://www.diydoctor.org.uk/projects/boilers.htm
