24 Sep 2016 at 21:44 #1 413x 413x Caporegime Joined 13 Jan 2010 Posts 33,551 Location Llaneirwg Looking for options as house I'm in isn't suitable for powerline connections. Max transfer rate is 3.5 MegaBytes per second from server to HTPC Has wireless come on far enough that this is viable option?
24 Sep 2016 at 21:48 #2 Akagi Akagi Caporegime Joined 29 Jul 2011 Posts 37,190 Location In acme's chair. Short answer, yes. If you buy the right kit.
24 Sep 2016 at 21:48 #3 bledd bledd Don Joined 21 Oct 2002 Posts 46,860 Location Parts Unknown Just cable it up
24 Sep 2016 at 22:05 #4 413x 413x Caporegime OP Joined 13 Jan 2010 Posts 33,551 Location Llaneirwg Recommendations for right dongles or kit? I only need to stream blu ray quality. Main problem I see is that I need to wake my microsever using WOL. So do I need an ethernet cable to wireless access point or something?
25 Sep 2016 at 07:35 #5 bledd bledd Don Joined 21 Oct 2002 Posts 46,860 Location Parts Unknown No, I mean run ethernet from the router to each device.
