Hello
I'm about to have a load of work done on our house, including an extension, and significant remodelling on the ground floor, which is where our router is situated. Since we're also going to insulate the outside of the house I figured it'd be a good time to run CAT6 cables to all the rooms on the first floor. I saw a useful guide on here about wired networking but have a couple of questions (apologies if obvious - I don't want to screw it up):
1] Our router comes in on the ground floor where we'll be keeping the TV etc. Would the right thing be to just run all the cables from all the upstairs rooms down to the ground floor and connect them into the switch that way? I.e. terminating into labelled junction boxes on the ground floor and then connecting from those into a switch which is connected into a router?
2] It seems you can pay anything for a switch - are there any brands or standards to avoid? Any harm in going for a bigger one (like 16 ports) in case I need to expand?
3] Can you recommend any good hardware for managing internet access? As my kids start to go online independently, I'd like to be able to control internet access in terms of sites and making sure it's off at night. (ideally controlling the use of VPNs as well)
4] We do have a loft space - so potentially could move the switching gear upstairs to the loft, but I can't see a reason to (the guide suggested doing this though)
5] We also have a wireless mesh system in place - a linksys velop. So we'd run that in parallel with the wired network. Any issues with that?
Thanks so much in advance!
