How Accurate Are PSU Wottage Calculators
6 Jun 2005
Church Fenton
I just put the following into a PSU calculator:
4400 @2.75Ghz 1.65v (209W)
DFI-Expert
1 stick of Corsair RAM
6800GS
In total that comes to 541W at 100% load thats without hardrives and extras put in.
Im using a 600W Seasonic.
Are these calculators accurate or am I "hurting" my PSU?
If so ill have to clock down because silence is golden. ;)
I think I read on an earlier post that you should take 30% of that calculation off.
So, 541/100 = 5.41
5.41*30 = 162.3
541-162 = 379W apparently, but that seems way too low. Your 600W will be fine for a long while.
*edit* - What case have you got that PSU in? I'm interested because that's the PSU i'm looking to get for an Antec P180.
It depends what calculator you are using as some will be more accurate than others, basically I'd say providing your system is working and the rails are stable then you shouldn't worry about it too much. I'd suggest the PSU calculator you are using is over-estimating by a fair margin, those 4 components will be the most power-hungry but not a chance do you need 500w+ just for them.
fenderbass86 if I am thinking of the same post it says to add on 30% in the Outervision calculator to allow for capacitor aging.
So, 541/100 = 5.41
5.41*30 = 162.3
Thank you. It was just that it was getting rather hot on the touch. Ill plug in the fan sensor the see if it spins up or not.
Im using the akasa eclipse. This PSU is very very good perfectly silent and I mean that. 720 rmp on the fan standard.
*edit*
Im using the extreme outervision calculator.
