How am i doing?
13 Jun 2011
Sorry screeners are at different times, primed over night and turned pc off before going to work.
phenom 2 x6 1090t @ 4ghz 1.45 v core
kingston hyper x greys 4gb @ 1.75v
Cross hair iv mboard
primed for 8h max temp was 59'c.
cant seem to get much further than this without going any higher on the voltage which results in higher temps maybe watercooling is in order!, but concidering i had a 1050t and it would only do 3.8ghz at 1.6v im much happier with this chip :)
How am i doing?
forgot to ask if anyone knows why different cores completed a different number of tests?
I thought that HyperX Genesis Grey runs at 1600Mhz? In your CPU-Z screeny it is saying that it is only running at 819.5Mhz.
