How Best To Power Gfx Card - Corsair AX860w
Caporegime
8 Jul 2003
In a house
At the moment, im powering my OC'd 290X just by the 1x cable, that has got 2x PCI-E 6+2 Pins on it, but im now thinking about running it from 2x seperate ones, as i'll in there tomorrow giving it a clean, so just wondered if it would be better, will it be spreading the load, or would it not matter, seen as my PSU is a single 12v rail ?
I know some have said they can burn out using just singles, but ive always powered it via the 1x cable, and never had an issue, but i don't want any either :p
I would personally use both cables
in my none professional evaluation of the situation
if the one cable is getting x amount of watts through it
the two cables will be getting the same x amount of watts
surely this may help the longevity of the cables health?
Or I could just be being stupid.
Yeah i was thinking about the load going through the 1x cable, has to be better spread over 2x, so ive popped another one on, thanks. :)
Needed that clean, wasn't that long ago i done it though tbh, but the amount of dust in the filters of my case fans, there must have been hardly any air getting in or out :eek:
My card was idling at 52 yesterday (with a fan speed of 21%), its only 47 today (with a fan speed of only 18%) after the clean (idles higher than normal, due to being on 144Hz, so my memory always runs full whack) :D
