How best to record Skype Video AND audio
28 Mar 2012
UK
Hi guys,
I need to record some Skype calls, both video and audio which at first would seem simple but apparently the free screen recorders only record video not audio...
Do you guys have any suggestions?
I am probably going to be using a standard webcam for video and will be using a headset to listen and speak during the skype call.
Thanks
You should be able to do this with the free Open Broadcast Software (OBS). This is really popular with Twitch streamers, however you can set it to record to a filepath instead of broadcast to a Twitch stream. It's pretty decent at selecting the source too, so you should be able to either select the entire desktop, a specific window to record, or select just part of the screen to record. I'm not on the machine I have OBS on at the moment so I can't look myself, but after a quick google this link gives you a few steps to get you started https://lifehacker.com/how-to-stream-or-record-your-games-for-broadcast-online-1702860349. It's a little old but it should get you on your way.
Have a google about and there are bound to be more guides, YouTube walkthroughs etc.
Hi guys,
Thanks
That is an erroneous statement.
Get OBS. It's free and it'll do what you want.
I'm sure I read pros and cons of certain recording software and a few had 'records video only'. This wasn't OBS, but 3rd party comparisons. Maybe I was wrong, but I found it odd enough to start this thread.
In the end I got an app that works well, though it isn't OBS. I'll try and play about with OBS as it may come in handy.
Thanks
