So I'm having some problems with my PC since I upgraded the CPU - I think its either the PSU or the motherboard's on the fritz. Could it be that I dont have enough juice?
AMD Opteron 165
Asus A8V Deluxe mobo
1GB Crucial DDR400 (Dual Channel)
Leadtech 6800GT (AGP, Big copper cooler)
1 Hard disk, 1 Optical drive.
3 Case fans
Its running on an Antec 380W PSU, but its pretty old. Could that be the problem? Should I be upgrading my PSU or my mobo?
I'm thinking try the PSU and see if the problem goes away, and if not upgrade the mobo as well?
What sort of wattage would you think my rig would need?
AMD Opteron 165
3 Case fans
