How big is a Razer Mamba?
16 Jun 2004
Basically, I had a Lachesis but found it to be a little bit on the small side for me, but most of all I found the thumb buttons hard to locate and press. Just wondered what it was like in this respect. (Maybe I've odd thumbs!!)
Pretty much the same size. I just took this pic.. sorry about the quality. :o
I'll post others if you need them. :)
I've got one and it's perfect in terms of how it fits your hand, assuming you have biggish hands anyway. I'd highly recommend it, it just bugs a little bit atm but i'm sure with the final release of Win7 it'll be totally fine.
And the side buttons are perfectly placed, but they're not on both sides like the Diamondback (I don't know about the Lacheisis)
The quick dpi buttons are a godsend as well, especially with games that have dodgy sensitivities ala Op Flashpoint 2.
