How big will graphics cards get?
18 Jun 2011
I ask this as I am worried that I have just bought a new rig and am worried future cards may not even fit.
Here are my relevant specs
Mobo - MSI P67A-G45 Intel P67 (Socket 1155) DDR3 Motherboard (Sandybridge) ** B3 REVISION ** [P67A-G45]
Case - BitFenix Shinobi
Thoughts?
70 inches
Srsly, nobody really knows. Chances are, unless everyone gets really large cases all of a sudden, they'll probably be at most 15inches long but will be roughly the same length.
If you look at them, the high end cards from years ago are the same as their 2011 equivalents.
I don't know your case, however, I reckon you could fit a 570 sort of length in there. That's roughly 11 inches which is the length of the high end single GPU cards
