How bottlenecked would a 660ti be with a Q6600 @3.2?
19 May 2005
Lancashire
I'm currently in the process of upgrading my computer as i'm starting to have to turn down settings on the latest games. My GTX280 has been great and has lasted me 4 years, but i think its time to get something better.
I was all set on getting a 3570 and 8gb of ram but I'm now just wondering if there's any life left in my Q6600 and 4gb, or would it bottleneck the 660ti? My temps are great so I could possibly push the clock up to 3.4 if that would help.
Thanks.
The output from the GPU still has to be processed by the cpu and it will bottleneck the card.
In Jan 2011 I went from a Q9450 @ 3.6ghz to an i7 2600k at 3.4ghz with the same AMD 6870 and I got about 15% higher fps in all games.
It will be a bottleneck in some games but not to a massive extent. Get the card and see how it plays. If you notice a bottleneck being too much in fps, upgrade the CPU/mobo/ram.
I saw no bottlenecking on a 560ti and a very small amount (GPU usage at 95%) on an overclocked GTX 580... so there will be a bottleneck but it won't be massive
if you are thinking of getting the 660ti and then upgrading the rest later then I'd say do it
otherwise you may as well save some money and get a 5xx series card if you can find one going cheap and save the money towards a system upgrade sooner rather than later
Thanks for the input guys. I will be upgrading the lot at some point, but with Christmas coming I was thinking of just the gfx card for now. Also just seems a shame to upgrade when this pc is still going strong. But then again my SSD would run faster on a new motherboard so might be worth it...
