How can 200mhz in BF3 make a difference?
18 May 2010
I upped my CPU from 3.4 to 3.6 at the weekend, I was surprised by the difference in BF3
Anyone know why this might be, I wasnt expecting the difference to be that noticable but it seems a fair bit smoother
Its a Phenom 965 and the GPU is a 560 Ti
Did you check average fps before and after or are you just going on feel? Might be a combination of placebo+actual difference that you're noticing :)
I know what you mean about placebo but its definitely not that, I play it enough on this setup to notice any changes and theres a definite difference, unfortunately I didnt measure FPS, wish I did but I just decided to up the multiplier to see what happens
I didnt touch any ram settings, I manually set the CAS when I first built it but everything else is on auto
If you were CPU limited you might have just alleviated enough of the bottleneck to pass the smoothness threshold.
Processor can make quite a lot of difference in these newer-gen games, I find. Perhaps some sort of bottleneck. I generally advise overclocking as far as possible to play BF3- it seemed to improve my FPS a lot more than GPU overclocks.
Worth bearing in mind that even if benchmark scores of average fps don't change much, a lot of the time minimum framerates (during massive fights) are dictated by cpu limitations.
