This month I've noticed that my allowance has gone a lot quicker than usual despite my usage being similar. Usually EE is a few hundred Mb out which is fine, but they're about 2Gb off!
On the 19th of this month, 1.5Gb off...
Today it's gone down by another Gb after using only 600Mb
I reset at the start of the billing period to keep things simple, I know that packets lost or retransmitted still count as I have a basic understanding of how the usage is measured but is it worth raising because I am probably going to end up buying a package to get me through the rest of the month. The previous month I still had about 2Gb left at the end of the billing period and usage has been the same!
If it's any use my Voda devices are all within 3% with usages from a few 100mb to one 10gig+. I tried to look into overhead for you this morning and everything I can read says >5% = problem somewhere as the billing system is really pretty good these days, overhead is slightly different depending on the radio interface but not enough to alter beyond a couple of %.
. Will do today and report back.
