How can I achieve a 3D effect for text?
6 Jan 2006
Newcastle upon Tyne
Has anyone seen the SyFy channel logo? Link here
Is there anyway this can be done in Photoshop or can someone recommend a way to do something similar? A freeware program would be ideal if not able to do it in Photoshop.
Thanks
I think that's a 3D render, probably made on Cinema 4D or something similar.
That's what I'd use to make something look like that anyway.
Actually really easy to learn, plenty of videos on Youtube.
Is cinema 4D free?
As said, that's a render. Not impossible to mock in PS but you'll spend longer getting the lighting as nicely done.
Could easily reproduce that in Blender, even the built in rendering engine should give you something quite close. For a more realistic render you could try using the cycles renderer. Blender is free, fantastic program.
