How can I add a 970 Evo plus to my old z77x ud5h?
Can I buy some type of PCI card or something? As I'm sure it won't work directly
Thanks ☺️
Yes, use something like a Asus hyper m.2 x4.
Use a gen 3 lane from the CPU for full speed. edit - if you're using an Ivy cpu.
You won't be able to boot from it, just use it as storage. But booting from it is possible with a bios mod.
