How can I add a nomenclature in word 2007?
29 Jun 2004
Hi, I'm writing a document with a lot of equations and Greek letters. How can I add a nomenclature to Word such that when I type an equation, I can define each letter and the nomenclature at the end of the documet can then update.
I can do with with the references, but ideally want to do the same with a nomenclature if at all possible.
Ta :)
Not 100% sure on what you're asking tbh.
Couldn't you just add an appendix, or insert horizontal line at the end of the document followed by a table or similar of your letters?
