How can i best take advantage of my onboard sound?
8 Dec 2014
As you will know by now i am getting a new PC and it has very good on board sound. I only use headphones so how can i best make use of the sound. Will a set of headphones with 2 jacks get best quality or can you get headphones with numerous jacks for each output, i think it is 5.1?
Would i be better off getting a USB headset with it's own sound in built?
Need help as i don't know much about this?
Thanx :)
Eh?? Oh ye i see what you mean. BUT does the main body of the OP not explain things to you??? Why the need to reply with such silly nonsense??
Thanx
Silly nonsense?
It's customary when asking for help to list the equipment you are using, otherwise those responding would be flying blind.
Silly nonsense?
OK point taken :)
I will be running :-
5820k
Asus ROG Rampage v
32GB ram
GTX 980
So the motherboard has "Supreme FX 2104" on Board sound http://www.asus.com/uk/Motherboards/RAMPAGE_V_EXTREME/
HyperX Cloud. The on-board will do them justice. Mic is average but detatchable if you want to get a dedicated mic.
Koss Pro DJ100's are a good rival for the Aurvana Live's, I opted for the Koss' in the end because of the far superior build quality. They were fantastic for what I paid, which back then was far more than their current £53 price tag!
I upgraded them to Fidelio X1's in the end.
People often compare the Pro DJ100 to the ATH-M50, which is well over double the price. The Pro DJ100 isn't as comfy though.
