- 13 Jun 2003
- South West
Hellooo
I am after anyones help with this please. My situation is as follows:
I want to be able to use sage 50 on a main pc and two laptops anywhere in the country plus recieve/send emails.
I would like to be able to have sage 50 on my pc at home connected to the internet and then buy two laptops and the o2 3G and GPRS internet cards and send invoices from the main pc using the laptops?
What is the best way to do this? I would also like to be able to do the same with emails.
Is the best way to do this remotley control the main pc some how or to have the software on each laptop and connect to the pc using that?
Any help with this would be so so so good!
Thank you in advance!!
BigMac
BigMac
