How can I download 8.1 when I only have an OEM product key?
10 Jun 2006
W. Yorks
I have just purchased myself a Acer Aspire V5-122P laptop and I wanted to install an ssd drive in it but I am struggling to get the product key to work on the Microsoft 8.1 download page.
I am aware of the workaround i.e start the 8 download and then cancel and then download the 8.1 iso but when I input the OEM product key it wont let me use it as it says it needs to be retail.
I do have a retail key but its for 8 Pro and the laptop is not using the Pro version.
I had to find the key on the laptop using Jellybean.
Is there anyway I can do a full fresh reinstall of Windows 8.1 on this lappy or am I snookered?
Will I be able to use the .iso I downloaded using the product key for 8 Pro as long as I download it on the laptop I am going to install it on?
Only the laptop came with just the core version of W8
I have tried this and it doesnt work. A Win 8.1 Pro .iso does not revert to Win 8 Core if you use a Core product key. Ah well back to the drawing board. :p
I ended up just cloning the drive onto my SSD. Not ideal but I never feel comfortable with downloading torrents.
They *are* the MSDN ISOs, they're bit-for-bit identical to the ones hosted at MSDN/Technet. You can check the SHA-1 hashes if you don't feel comfortable that the evil act of torrenting won't somehow change good bits into bad bits.
Thanks for the advice but I think i will stick with the cloned installation. I never know where to look for torrents anyhow. The first couple of suggested sites had been closed so it scared me off. :eek:
