squiffy said:192.168.0.2 is your router IP address. Your PC's IP address is given and shown on "connected devices" or similar, and is automatic.
Macabre said:Why does it matter what it is set as?
squiffy said:Sometimes it moves IP address of a certain PC, so if you have port forwarding to that machine it will no longer work if that machine isn't the downloading box. Would be useful for DHCP to keep each LAN IP address fixed.
[Sniper][Wolf] said:Just set the pc you to use a static ip, when the router issues out ip address through DHCP it wont assign an I.P address thats already been assigned statically, it will assign the next available address.
Set your router to 192.168.1.1, set the pc which you use for downloading as 192.168.1.2, enable DHCP on the router, all the other machines in your house set to pick up an address automatically.
When one of those machines then turn on it will get the next available address which will be 192.168.1.3, then 192.168.1.4
Zap said:bad idea, if the machine with the static IP is off when another machine turns on it will be given the same address and potentially cause an IP conflict. hence why i said above that the dhcp range needs to be changed. To set a manual IP go to network connections, right click on LAN, properties, double click tcp/ip and enter your settings there.
IP - 192.168.0.2
Subnet - 255.255.255.0
Gateway - 192.168.0.1
DNS - use your ISP settings.
pinkegobox said:can you're router not assign specific ip addresses to specific MAC addresses?
pinkegobox said:can you're router not assign specific ip addresses to specific MAC addresses? my dg834g can, and that's old now... that way my server is always on the same address and stuff like port 80 forwarding works.
and do you really need ports forwarding for steam? I know i don't through my router... as me and my bro often connect to the same server to play against each other, and that wouldn't work if we were forwarding ports?
IP - 192.168.0.2
