I'm in the process of putting together a new PC. It's going well and currently it’s at about £700 (bar the GFX) for an i7, SSD setup. Very happy so far.
However I just can't bring myself to spend £350 on a graphic card (currently looking at the 7950). The problem is that it fits my spec perfectly in terms of noise, power, and power consumption.
Are there any cards out there that are roughly the same for gaming at 1920x1080, have the same idle/load noise (very important) and are generally the same temps? BUT, for about £200 instead? I'm will to take a bit of a hit to performance if it's saving me £150+
I did take a look at the 480 but I'm quite keen to get current gen.
Is it worth waiting, if so, what am I waiting for and when will they be released?
Any suggestions or recommendations would be massively useful.
Thanks!
Thanks!
