How can i monitor NB temps
Eh ?
I'd like to know as well.
Abit uguru on the IN9 lets you see cpu, system, and pwm phase 1 to 5.
I wonder which of these is the NB ?
As far as I know, 'system' IS the NB temp.
In the manual, it refers to the 'System' fan as being the fan that goes on the NB heatsink...
I could be wrong though :D
System is the Southbridge temperature on all NVidia chipsets. If you think about it, there is no way 33C is correct given that the heatsink (not the chip underneath it) is very, very warm indeed. This has been the case for NForce4, 5xx and 6xx S775 motherboards. I don't know about the AMD ones though.
There are intel standards about the minimum number of fans and what they have to be called. One is called Power - have you noticed that?
FlakMagnet said:
So, how do you measure NB temps?
Personally, I put the back ofmy hand on the heatsink and if I can't touch it comfortably, it's a little warm.
FlakMagnet said:
And what value is considered too high?
There isn't really anything "official" Too hot is too hot. What are you worried about in particular?
lol - I like that :p
Just worried about damaging the NB. I need my system to last me 2 years, so I just want to run comfortably within its bounds and not stretch any component too much.
Apart from that, I'm really too bothered how hot things get.
I actually had this in the small claims court because a motherboard I was using failed while I was overclocking with it. The shop (not OcUK) said they wouldn't give me a new one or process my warranty claim because I had been overclocking and therefore voided the motherboard warranty. I argued (successfully) that if the BIOS options allow a user to set something in a particular way and the box says 'Ideal for Overclocking' or something similar on the front then the motherboard should be able to handle any of it's own settings without melting.
The motherboard is the one thing you can overclock to death and take back under warranty with complete impunity!
