Permabanned
- 13 Jan 2010
- UK
When It comes to overclocking, I'm, still pretty noobish :/
I recently bought an i7 system with great cooling but need some help overclocking it, how do I do it ?
Theres all my components, got a build thread too if interested.
Please can you give me some step by step guidance to get it up to 4ghz.
Also running two pwm splitters for my apache fans and case fans, but everything seems to be running at full all the time, what can I do to stop this?
The 3 Akasa Apaches are running in a cpu cooler tunnel effect (push/pull/exhaust) and are PWM but the top exhaust and the two front fans are 3-pin voltage and also running on full. On the BIOS I've loaded optimised set up on UD5 and set up smart fan control running with PWM but this is not making any difference, still running full.
*my build http://forums.overclockers.co.uk/showthread.php?t=18110539
What should I do ???
