How can i permanently set my fan speed lower
18 Nov 2007
I've got an arctic 7 cooler, but the fan always funs stupidly fast, and loud, but i can get pretty much the same perfomance on say 60% using speedfan, which is great, but how do i set the speed permanently?
well you can use speedfan to set it at 60% the whole time, or just limit it to 60% max, on speedfan just set the temp sensor you want to use as automatic control, set the fan speed to say 25%-60% and then tell it to automatically adjust fan speed
