13 Feb 2009 at 17:21 #1 chris_uk333 chris_uk333 Associate Joined 11 Sep 2008 Posts 1,206 So i have a music dvd and i wanna know if i can record the sound from it...Is there any way? It's just i want some of the songs on mp3. Cheers!
13 Feb 2009 at 17:25 #2 yashiro yashiro Soldato Joined 9 Dec 2003 Posts 3,620 Location UK http://www.doom9.org/software.htm
13 Feb 2009 at 17:30 #3 Energize Energize Caporegime Joined 12 Mar 2004 Posts 29,962 Location England Just use dvd decrypter to rip the dvd and then convert the audio to mp3 using something like audacity to edit it.
13 Feb 2009 at 17:32 #4 RobH RobH Soldato Joined 9 May 2005 Posts 4,530 Location Nottingham Or if you're really lazy just use Audacity to record the "what you hear" channel as you play the DVD.
13 Feb 2009 at 17:34 #5 chris_uk333 chris_uk333 Associate OP Joined 11 Sep 2008 Posts 1,206 thanks guys, appreciated greatly
13 Feb 2009 at 17:42 #6 chris_uk333 chris_uk333 Associate OP Joined 11 Sep 2008 Posts 1,206 when i try to record on auda city it doesn't work
13 Feb 2009 at 17:48 #7 chris_uk333 chris_uk333 Associate OP Joined 11 Sep 2008 Posts 1,206 i take it you need a sound card? i dont have one
13 Feb 2009 at 18:27 #8 tonyzero tonyzero Associate Joined 29 Oct 2003 Posts 1,394 Location Perivale, London chris_uk333 said: i take it you need a sound card? i dont have one Click to expand...
