how can I set rgb fusion to a certain light without it defaulting?
16 Feb 2011
Liverpool
I bought a x570 aorus ultra not long after release and I really hate this software it causes my corsair stuff to show different colours in particular my h100i platinum SE if I have RGB fusion on boot it will make my aio show yellow ish white (like old warm bulbs) or if I set it as red it will show like a pink. BUT if i dont have rgb fusion to start on boot it defaults (the gigabyte rgb led strip and io etc) to orange i've tried uninstalling the software after setting the colour as recommended by one of the gigabyte reps, really wish I went with asus never had any of these issues with them.
edit forgot to mention the corsair stuff has no issues if rgb fusion isnt set to start on boot.
Pretty sure it doesn't have to run at startup to set the colours, but if you remove it altogether it goes back to the urine coloured default. Have you tried setting it up how you want then just unchecking run at startup from RGB Fusion settings instead of uninstalling?
