How can i setup a Wireless Ip Cam without a wireless router please?
5 Aug 2006
Northern Ireland
hi
i have this wireless ip cam but my router is wired and i was wondering how i can set it up because i have nothing for it to communicate to my pc.
thanks
Typically you set up a wireless network, put your machine on the same LAN then devices like that either come with an app CD that contains a discovery app or some devices will join the first open network they find and you go from there.
I'd imagine that the former is the most likely, but read the manual to be sure. :)
