My PC refused to boot today: I’ve swapped the PSU and GPU into a different system and they’re fine, as is the case’s power switch
The motherboard/CPU/RAM combination won’t boot though - It’s possible it’s the RAM but I’ve switched sticks so unless they’ve both gone simultaneously it’s unlikely
So that suggests it’s the Mobo or CPU. Neither of my cases has a case speaker so I can’t listen for post beeps
When I plug the PSU in (when connected to the PC) the motherboard’s LEDs light up for a split second then go off. When pressing the power button I get literally nothing - not even a jolt of the fans.
Any suggestions? I’ve ordered a motherboard speaker, and I’m trying to find another LGA 1151 CPU or motherboard to try to try to narrow it down, but unsurprisingly nobody is proffering their CPU or motherboard up to potentially be fried
CPU is an 8700K from OCUK, Motherboard is a Gigabyte Aurus from the place with all the trees, and I believe both are still under warranty
