Hi
I am running Feisty and my system sounds don't work, or i should say no longer works, as they used to.
Movies, MP3 etc (and even the little drumming sound at the login screen) work fine but the system sounds that play after you have logged in don't work.
I assume i must have installed something that messed things up somehow? Any idea how i can track down what the problem might be in order to try and fix it?
thanks
thanks
