How can you set monitor refresh rate in crysis
Caporegime
27 Nov 2005
Guernsey
Crysis is trying to run at 1080p 24hz when i try to play it on my plasma....
How can i set crysis to output a 1080p 60hz signal :confused:
Does anyone know of a command i can put in the System.cfg text file to set the monitor refresh rate please ??
I know of the command for setting the game resolution.
r_Height [value] - This command controls the height of your screen resolution in pixels, and when combined with the r_width command, can be used to set a custom resolution if you wish.
But not the refresh rate...:mad:
No replys.....Am guessing there no command available for being able to set the monitor refresh rate....
Just got hope and pray that they bring a patch out very soon to fix this very bad bug....
Try an app called reforce or do it in control panel of nvidia/ati
Thanks
i have a look for this app and try it..(does it work in vista 64bit ??)
The only setting in the nvidia panel are for the desktop...which i have set at 1080p/60hz but when i start crysis the res changes to 1080p/24hz
I still have not found a way to run crysis at higher then 24hz :mad:
