Hi guys I was wondering how cheap I could build a NAS for. I have some DDR2 RAM knocking around and I was wondering how cheap it would be if buying second hand. Not sure what spec I would need I have the hard drives, got windows 7 or server so it is really just the hardware that needs sorting.
I want it to use as little power as possible is there much difference from using an Atom vs an under clocked AMD / Intel 775? I assume I could maybe set the server to wake on Lan? If so maybe the power saving wouldn't matter too much. The server is going to host about 1Tb of movies and some songs and then file backing up for all the PCs / laptops in the house about 5 including media centres.
If someone could tell when what sort of prices I should expect to pay that would be great
