I have tried googling & got nowhere so thought I'd ask opinions here.
I have an almost finished engine conversion but have been unable to avoid running the hose that feeds the heater matrix from the engine rather close to where the exhaust manifold meets the yet to be fitted downpipe.
I am using standard rubber coolant hose, is this likely to withstand being 1.5 inches away from the exhaust or is it likely to end up with a major coolant leak?
