I noticed on the mini description tag for the "Asus X58 Sabertooth TUF" Intel Motherboard (the bit you can see when viewing it from the components page, but not from within it's description) it says "Built with military grade components the X58 Sabertooth can operate in both extreme temperatures and sub zero conditions."
Is it actually true that it can operate in "sub zero" conditions... because a mate lives in a shop and we were thinking about sticking a PC in the cold-store (about -24C) to see if it would overclock well as a seti rig... but since even SSD's claim they only operate down to about 0 degrees C I'm guessing this is just hype?
(obviously we know mechanical HDD's won't work in there... but we were thinking of running a sata cable through a small gap to the outside air so the HDD could still be warm)
