how come i can run at...
6 Oct 2005
Um...
Why can I run at 8 * 410, but not 9 * 350. Which is actually slower CPU and memory rating wise?
I dont get it.
Anything that would cause this?
I'm on a p5q-pro with Q6600.
Cheers.
I've seen other people mention that their quads clock better on the x8 multi.
Tho it's usually nearer 3.6ghz that the oddity occurs. I would expect any Q6600 to do 350x9.
mine clocks better on a x9 !
I'd say you've probably come up against a motherboard limitation, as on the higher fsbs it probably drops to a lower strap
anything past 3.2Ghz is more stable with the 8x multi on my cpu/mobo. I have never figured out why.
And definitely not a fsb hole either.
