I have a standard terrible Talktalk router that isn't wireless and theirs 3 other computers in my house so I had to buy an ethernet hub and connect the other computers that way.
I still have a few spare ports in the hub and I'm wondering if theirs a way to send out a wireless signal so I can connect my laptop to it, without having to buy another router.
I was speaking to some one and he said it's possible by using a Wireless Access Point.
The description of the product says :
'108mbps Super-G Wireless Access Point (also compatible with 54mbps Wireless-G 802.11g and 11mbps Wireless-B 802.11b)
Allows you to connect your network wirelessly better than ever, easily and securely. Provides multiple security protection measures. Can be set to turn off wireless network name (SSID) broadcast so that only stations that have the SSID can be connected.
Complies with Super G 108mbps and the IEEE 802.11g/b standards and adopts 2x to 3x eXtended Range? WLAN transmission technology so that transmission distance is 2-3 times that of traditional 11g/b solutions, up to 855.36m. (When used with XR-compatible equipment; standard 802.11g range otherwise). Range extended to 4-9 times. Compatible with all IEEE 802.11g and IEEE 802.11b products.
PLEASE NOTE: This is a wireless access point with a single wired network (Ethernet) connection. It is not a full router.
Specification
* Super-G 108mpbs (when used with Super G compatible equipment)
* IEEE 802.11g, IEEE 802.11b
* Wireless Signal Rates With Automatic Fallback
* Wireless Range: Indoors up to 200m, Outdoors up to 830m.
* SSID Enable/Disable
* MAC Address Filter
* 64/128/152-bit WEP Encryption
* WPA/WPA2/WPA-PSK/WPA2-PSK (AES/TKIP) Encryption
* 1 10/100M Auto-Sensing RJ45 Port(Auto MDI/MDIX)
* Antenna
* 3dBi Detachable Omni Directional Antenna'
If I buy one of those, how would they work? Would I just have to connect an ethernet lead from the hub into the wireless acces point?
Cheers
Specification
* Antenna
Cheers
