how could i run battelfeild 3
I don't know how the CPU compares but I play on ultra using a Q6600 @3.0GHz, 8GB RAM and a 2GB 7850. At 1680 x 1050. It runs great on this rig.
just depends on fps you comfortable with and the res you have your screen set to etc
1680 x 1050 is the recommend default for a 22", drop it down a bit and frames go up but for me don't look as good etc
I would always recommend playing at the screen's native resolution and adjust options from there.
Ultra should be playable at 1080P dependant on AA settings.
Assuming it's a 1080p TV, it should play at high to ultra perfectly fine. I have a Q6600 @ 3.6GHz and a 6950 2GB and it plays BF3 on ultra on 1080p at around 50fps.
