Wishing to pick the collective brains here
Picked up a DK2 in mint condition for 75 quid over christmas as a quick and dirty way to try out vr, figured if it's a bit crap it's not the end of the world (I won money in the solidworks2019 beta test bug hunting competition so not out of pocket either way). I fitted a matte screen protector with pretty much eliminated all screen door effect (looks like it's got a very soft blur filter on it now) and generally it's all working as intended using the latest oculus drivers. Can't adjust the ipd but by happy coincidence mine is 64mm which is bang on for the dk2.
My machine is below spec (officially), it's a [email protected] with an evga gtx780sc so I get all the warnings in oculus dashboard but plays most things quite happily with no judder for the most part. Fallout4 struggles a bit (using vorpx) but I think I prefer it maxed out @1080 than in lower quality 3D but elite and alien isolation run really smoothly.
In elite, I have everything on ultra, sampling at 0.85 and and hmd supersampling at 2x and it's all sharp, looks great and is perfectly smooth, framerate on the monitor is around 50-70fps dropping to 30ish in stations.
Now how critical is it that you hit the refresh rate? The DK2 is 75hz so by all accounts I should be getting motion sickness and generally not be particularly comfortable, but I'm not, I can quite happily sit there for three hours nonstop (by which time I have to wake up in 5 hours time). Am I just lucky and not affected by low framerate VR or is there something else going on? Any thoughts?
Overall it's awesome and perhaps the best £76.89 (£1.89 for a pack of 5 screen protectors) that I've spent on my pc
