How deep for the footings?
I wouldn't have thought you would have to take them all out as for all you know they could travel across the garden. As long as they are chopped off should be good
The cinder blocks you have pictures are great for building that sort of wall they are designed to be filled once each course is complete, either with mortar or 10mm to dust hard core compacted.
Just cut the roots off, before you put concrete down you will need a bed of hardcore 10mm to dust compacted to give you a stable base.
If Carlsberg did posts
Thanks so much!
I don't know... He said I should have dug down to sand level,.. I can take the hardcore out and add sand? Then put the hardcore on top of it... He was saying soil isn't as solid as sand and I should have dug until I reached it...
He's done ground works for 30 years... Feeling abit confused now..... Isn't there always sand below soil?. . I haven't a clue lol
Thanks in advance for any help
